iPhone 15 Pro Max Loudspeaker Replacement
  1. iPhone 15 Pro Max Loudspeaker Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Pro Max Loudspeaker Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Ask FixBot
  2. iPhone 15 Pro Max Loudspeaker Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Pro Max Loudspeaker Replacement, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Ask FixBot
  3. iPhone 15 Pro Max Loudspeaker Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  4. iPhone 15 Pro Max Loudspeaker Replacement, Remove the pentalobe screws: step 4, image 1 of 1
    • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
    Ask FixBot
  5. iPhone 15 Pro Max Loudspeaker Replacement, Heat the bottom edge: step 5, image 1 of 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Ask FixBot
  6. iPhone 15 Pro Max Loudspeaker Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  7. iPhone 15 Pro Max Loudspeaker Replacement, Screen information: step 7, image 1 of 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    Ask FixBot
  8. iPhone 15 Pro Max Loudspeaker Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Ask FixBot
  9. iPhone 15 Pro Max Loudspeaker Replacement, Heat the right edge: step 9, image 1 of 1
    • Heat the right edge of the screen until it's hot to the touch.
    Ask FixBot
  10. iPhone 15 Pro Max Loudspeaker Replacement, Position the opening pick: step 10, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Position the opening pick: step 10, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Position the opening pick: step 10, image 3 of 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
    Ask FixBot
  11. iPhone 15 Pro Max Loudspeaker Replacement, Release the right clip: step 11, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Release the right clip: step 11, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Release the right clip: step 11, image 3 of 3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
    Ask FixBot
  12. iPhone 15 Pro Max Loudspeaker Replacement, Separate the right edge adhesive: step 12, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the right edge adhesive: step 12, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the right edge adhesive: step 12, image 3 of 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
    Ask FixBot
  13. iPhone 15 Pro Max Loudspeaker Replacement, Heat the top edge: step 13, image 1 of 1
    • Heat the top edge of the screen until it's hot to the touch.
    Ask FixBot
  14. iPhone 15 Pro Max Loudspeaker Replacement, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the top edge adhesive: step 14, image 3 of 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
    Ask FixBot
  15. iPhone 15 Pro Max Loudspeaker Replacement, Heat the left edge: step 15, image 1 of 1
    • Heat the left edge of the screen until it's hot to the touch.
    Ask FixBot
  16. iPhone 15 Pro Max Loudspeaker Replacement, Separate the left edge adhesive: step 16, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the left edge adhesive: step 16, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the left edge adhesive: step 16, image 3 of 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    Ask FixBot
  17. iPhone 15 Pro Max Loudspeaker Replacement, Swing open the screen: step 17, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Swing open the screen: step 17, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Swing open the screen: step 17, image 3 of 3
    • Gently swing open the screen to the left of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the screen against a box or similar object so it doesn't strain the cables.
    Ask FixBot
  18. iPhone 15 Pro Max Loudspeaker Replacement, Unfasten the logic board cover: step 18, image 1 of 2 iPhone 15 Pro Max Loudspeaker Replacement, Unfasten the logic board cover: step 18, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a tri-point Y000 driver to remove the six screws securing the logic board cover:
    • One 2.1 mm‑long screw
    • Five 1.5 mm‑long screws
    Ask FixBot
  19. iPhone 15 Pro Max Loudspeaker Replacement, Remove the logic board cover: step 19, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Remove the logic board cover: step 19, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Remove the logic board cover: step 19, image 3 of 3
    Buy
    • Use tweezers or your fingers to grab and slide the logic board cover toward the bottom of the phone to clear the sensor cable.
    • Remove the cover.
    Ask FixBot
  20. iPhone 15 Pro Max Loudspeaker Replacement, Disconnect the battery: step 20, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Disconnect the battery: step 20, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Disconnect the battery: step 20, image 3 of 3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
    Ask FixBot
  21. iPhone 15 Pro Max Loudspeaker Replacement, Disconnect the ambient light sensor: step 21, image 1 of 2 iPhone 15 Pro Max Loudspeaker Replacement, Disconnect the ambient light sensor: step 21, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the ambient light sensor press connector from the top left of the logic board.
    Ask FixBot
  22. iPhone 15 Pro Max Loudspeaker Replacement, Disconnect the screen: step 22, image 1 of 2 iPhone 15 Pro Max Loudspeaker Replacement, Disconnect the screen: step 22, image 2 of 2
    • Disconnect the screen press connector.
    Ask FixBot
  23. iPhone 15 Pro Max Loudspeaker Replacement, Remove the screen: step 23, image 1 of 2 iPhone 15 Pro Max Loudspeaker Replacement, Remove the screen: step 23, image 2 of 2
    • Remove the screen.
    • During reassembly, stop here and use this guide to install new screen adhesive.
    • Be careful not to damage any of the spring contacts as you clean the frame.
    Ask FixBot
  24. iPhone 15 Pro Max Loudspeaker Replacement, Unfasten the loudspeaker: step 24, image 1 of 1
    • Use your Phillips #000 driver to remove the four screws securing the loudspeaker:
    • Three 2.1 mm screws
    • One 2.9 mm screw
    Ask FixBot
  25. iPhone 15 Pro Max Loudspeaker Replacement, Separate the tape: step 25, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the tape: step 25, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Separate the tape: step 25, image 3 of 3
    • A piece of tape connects the top edges of the Taptic Engine and loudspeaker.
    • Insert an opening pick under the tape in the small gap between the Taptic Engine and the loudspeaker.
    • Slide the pick toward the left edge of the phone to separate the tape from the Taptic Engine.
    Ask FixBot
  26. iPhone 15 Pro Max Loudspeaker Replacement, Remove the loudspeaker: step 26, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Remove the loudspeaker: step 26, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Remove the loudspeaker: step 26, image 3 of 3
    • Insert the flat end of a spudger between the right edge of the loudspeaker and the frame.
    • Pry up until you can grab the loudspeaker with your fingers.
    • Remove the loudspeaker.
    Ask FixBot
  27. iPhone 15 Pro Max Loudspeaker Replacement, Remove the tape: step 27, image 1 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Remove the tape: step 27, image 2 of 3 iPhone 15 Pro Max Loudspeaker Replacement, Remove the tape: step 27, image 3 of 3
    • Peel the tape from the top edge of the loudspeaker.
    Ask FixBot
7 other people completed this guide.
Clay Eickemeyer
104,117 Reputation
476 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
17,861 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 63
Past 30 Days: 347
All Time: 8,400
