Introduction
滑丝的螺丝, 对许多热爱维修的爱好者是场梦靥。想说试试看再说, 但往往许多螺丝就是不肯被拧出。一旦当你的螺丝形状已变成“O形”的话,最后的结果往往是令人沮丧的。
但千万不要害怕,我们会当你的后盾。这个指南会教导你如何从螺丝头切开一小小的裂缝, 让你可以透过一字的螺丝起子, 来取出滑丝的螺丝。
技术:
使用旋转工具时务必佩戴护目镜,以防止碎屑或火花造成伤害。
Video Overview
当你的螺丝已呈现滑丝状态,而螺丝刀也起不了什么作用。在你准备要破坏前,请试试看以下步骤。
试着用不同的螺丝刀。先试小一点的或是螺丝刀头大一点的,看看是否能碰触到螺丝并让滑丝的螺丝转动。
如果以上这些方法都没有成效的话,恭喜你!你的螺丝已经自由了。
如果螺丝头可以轻易碰触到,你也可试试用钳子。若是你可用钳子有效地抓住螺丝头,当你拧钳子,螺丝应该也会跟着拧。
当螺丝有松一点的话,你或许也可以再试试螺丝起子再拧一下。
查看介绍中的视频,了解有关处理滑丝螺丝的一些其他提示。始终使用高品质的螺丝刀。 低品质的螺丝刀可能会导致螺丝损坏。
248 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
63 Comments
"To reassemble your device, follow these instructions in reverse order."
Yeah, that makes perfect sense... If you put the saw in reverse it glues all the buts of iron back onto the screw :-)
But other than that, this could be useful in some situations. Be careful,of the iron filings on your electronics!
Haha, good catch! We've fixed the conclusion. Apologies to all who tried so very hard to follow these instructions in reverse.
There's always the ultimate tool if it won't go out, the drill.
Of course you'll have to make new threads if you drill out a screw. However, as a "weapon of last resort", the drill always works.
Thank you for this guide. The Vampliers, however, completely removed the head of my T6 screw. There are two of them holding the display to the top case of my 15'' Macbook Pro. I am on one of the last steps in the Top Case replacement guide.
Can I use a drill if my screw has virtually no head?
Thanks!
