This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
屏幕破损?触摸不工作?损坏的OLED显示屏?使用本指南替换Galaxy S8 +中的显示屏+触摸面板部件,并将其恢复到完美的工作状态。
注意:本指南指导您在保留原始边框,逻辑板和电池的同时,仅更换显示屏。然而,一些更换屏幕预先安装在一个新边框中,这需执行另一种流程 - 移植你的手机的内部组件和安装一个新的电池。在开始本指南之前,请确保您拥有正确的元件。
要将整个屏幕组件替换为新框架follow this guide代替。
如果框架损坏或弯曲,请务必更换,否则新的屏幕可能无法正确安装,并且可能因受力不均而损坏。
将显示屏与框架分离的过程通常会破坏显示屏,因此除非您打算更换显示屏,否则请勿遵循本指南。
Video Overview
要重新组装您的设备,请按照指南相反步骤操作。
80 other people completed this guide.
Special thanks to these translators:
75%
These translators are helping us fix the world! Want to contribute?
Start translating ›
14 Comments
After replacing LCD my phone showing message that “Battery temperature too low“ and pause charging. There are some video showing install wireless charging module after replacing LCD would solve this issue but for me it still not charging even with wireless charging module on. Any suggestion?
samion 2048, This is because the device was turned on before attaching the wireless charging coil. The coil houses the ambient temperature sensor.
once you replace the front screen is the phone still water resistant?
It will be water resistant if you reapply the nescassery adhesives.
I replaced my display with a another display with mid frame attatched already.all i did was change over my mother board,charging port and such and now if i power the phone on i feel it vibrate and see a blue led light up but that is all it does.screen is black and i can feel the vibration feedback if i touch the screen but nothing shows.going out of my mind trying to figure out what went wrong.
