Battery
1 Answer 1 Score |
Can the backglass cover be replaced? |
1 Answer 0 Score |
Cellular RF front and scan test |
4 Answers 4 Score |
14 pro restarting randomly SMC PANIC - ASSERTION FAILED - BSC failure |
1 Answer 1 Score |
Unable to determine if battery is a genuine part -- Is it a problem? |
Documents
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A2650 US, A2889 Canada/Mexico/Japan/Saudi Arabia, A2890 Global, A2891 Russia, A2892 China
Wallpapers
Get your free iPhone 14 Pro wallpapers! Choose from iFixit or Creative Electron (X-ray) versions. Looking for more? Check out our other wallpaper posts!
Background
The iPhone 14 Pro was announced on September 7th, 2022, and released the week after on September 16th. As the "smaller" sibling to the iPhone 14 Pro Max, it features a 6.1" Always-On display but the same new A16 Bionic chip. Compared to its predecessor, the iPhone 13 Pro, this model’s Pro Camera System has a 48 MP main camera and a larger aperture across. The Pro-line’s Dynamic Island hides the top sensors and facetime camera.
Being a tad thicker (.2 mm/.01 in) and taller (1 mm/.03 in) than the iPhone 13 Pro, it also comes with a larger battery.
Identification
You can identify the iPhone 14 Pro by the one of the following model numbers printed on the inside back of the Lightning (charge) port. Flip the iPhone over (with the screen facing away from you) to see it.
- A2650
- A2889
- A2890
- A2891
- A2892
You can also find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
The iPhone 14 Pro features a 6.1 in (diagonal) flat glass screen, thin black bezels, and a new "dynamic island" at the top of the screen to accommodate sensors and the front facing camera. The back cover is glass and the edge frame is made from flat stainless steel.
Volume controls and the SIM tray can be found on the left edge while the power button is situated on the right. A rectangular camera "bump" containing three cameras in a triagonal layout protrudes slightly from the back case. This model has no home button.
The iPhone 14 Pro can be differentiated from the iPhone 14 Pro Max by the 6.1 in screen (relative to the 6.7 in screen on the Pro Max model).
Technical Specifications
Dimensions: 147.5 × 71.5 × 7.85 mm (5.81 × 2.81 × 0.31 in)
Weight: 206 g (7.27 oz)
Water Resistance: IP68
Colors: Space Black, Silver, Gold, and Deep Purple
Operating System: iOS 16 or newer
Processor: A16 Bionic chip
- 6‑core CPU with 2 performance and 4 efficiency cores
- 5‑core GPU
- 16‑core Neural Engine
RAM: 6 GB
Storage: 128, 256, 512 GB, or 1 TB
Battery: 3200 mAh, 12.38 Wh
Display:
- 6.1-inch “Super Retina XDR” OLED
- Ceramic Shield glass technology
- Multi‑touch
- Haptic Touch
- 2556 × 1179 pixel resolution (460 ppi)
- 2,000,000:1 contrast ratio (typical)
- True Tone
- P3 wide color gamut
- 1000 nits max brightness, 1600 nits peak (HDR), 2000 nits peak (outdoor)
- Fingerprint-resistant oleophobic coating
Pro camera system:
- Main module
- 48 MP
- ƒ/1.78 aperture
- Sensor-shift optical image stabilization (OIS)
- Autofocus with 100% Focus Pixels
- Seven-element lens
- Ultra-wide module (120° field of view, 2x optical zoom)
- 12 MP
- ƒ/2.2 aperture
- Six-element lens
- Telephoto (3x)
- 12 MP
- ƒ/2.8 aperture
- Six-element lens
TrueDepth selfie camera with Face ID:
- 12 MP
- ƒ/1.9 aperture
- ProRes video up to 4K at 30fps
- Six‑element lens
- Retina Flash
Sensors:
- Face ID
- Barometer
- High dynamic range gyro
- High-g accelerometer (Crash Detection)
- Proximity sensor
- LiDAR
- Dual ambient light sensor
Wireless Connectivity:
- 802.11ax Wi‑Fi 6 with 2x2 MIMO
- 5G (sub-6 GHz in all models, mmWave only US-model)
- Gigabit LTE with 4x4 MIMO (LAA only US-model)
- Bluetooth 5.3
- Apple-designed U1 Ultra Wideband chip for spatial awareness
- NFC with reader mode
- Express Cards with power reserve
Additional Information
- Official Apple page: iPhone 14 Pro
- Apple: iPhone 14 Pro repair manual
