Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Panasonic SL-MP73J is a portable CD player manufactured by Panasonic in Japan, and released in 2003. It has an anti-skip system, MP3 playback ability, headphone jack, and a durable, portable design. It was widely distributed across the United States, Canada, Japan, Australia, and other countries across Europe and Asia.
The intended user group is for people who want to listen to music on the go whether they are running or driving. There is a Jogger Soft Case that goes around the waist and comes with the Panasonic SL-MP73J so people can easily bring it on the go. It is not currently on the market, but you can buy it from resellers from $15.00 to $100.00 depending on the condition.
The malfunctions that come with the device tend to include, the CD not being read or skipping, corroded batteries, faulty AC adapter, issues with the Hold button, and overall power problems. With these issues, there are simple fixes like cleaning the CD, ensuring the laser lens is clean, and making sure the motor is spinning.
This model is extremely simple and easy to use. It is on the older side of compatible portable CD players and there is no direct replaced model of the Panasonic SL-MP73J. The device that came after was the Panasonic SL-MP75 which is very similar to the original device. It also includes a Display Panel, Hold button, Resume function, and Auto off function.
Identification
To identify the player, look for the Panasonic logo on the front of the player and the model number "SL-MP73J" below it. The shape of the player is circular, thin, and it opens with a gray slide switch on the side of the device. It is made primarily of plastic with one large metallic button and 5 small metallic ones. With these, you can pause, play, and skip music, as well as control the volume, mode, frequency, etc. There is a small display at the top of the device that displays the number of tracks in the CD, the total playtime, the number of albums, and the number of tracks. The device is mainly silver and does not come in other colors.
Technical Specifications
General
  • Dimensions (W x H x D): 135 x 28 x 135 mm
  • Mass: Approx. 230 g (with batteries)
  • WMA supported bit-rates: 32 kbps to 192 kbps
  • MP3 supported bit-rates: 32 kbps to 320 kbps
Audio
  • Frequency response of 20 to 20,000 Hz
  • Headphone output level: RMS max. 8 mW + 8 mW/16 Ω
  • Includes 3.5 mm headphone jack
CD player
  • Plays 8cm or 12cm discs
  • Plays discs in the following formats: CD, CD-R or CD-RW
Radio
  • Includes two channels (left and right, stereo)
  • Support for AM/FM radio
Power
  • Uses two AA batteries
  • Can also be used with an AC adapter or rechargeable batteries
  • Operational temperature range: 32°F to 104°F
  • Rechargeable temperature range: 41°F to 104°F
Source: Panasonic SL-MP73J Manual
Additional Information
Panasonic SL-MP73J Amazon Link
Panasonic Support Hub
Panasonic SL-MP80/SL-MP73J/SL-MP71C/SL-MP70 Portable CD Player Operating Instructions
Author
with
Samuel Farrar
151 Reputation
0 Guides authored
UMass Dartmouth, Team 1-8, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-8, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G8
3 Members
60 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 72
All Time: 641
