Panasonic SL-MP73J Base Plate Replacement
    1. Panasonic SL-MP73J Base Plate Replacement, Base Plate: step 1, image 1 of 1
      • Locate the open slider and push the sliding button to the right to open the CD player.
      Ask FixBot
    2. Panasonic SL-MP73J Base Plate Replacement: step 2, image 1 of 2 Panasonic SL-MP73J Base Plate Replacement: step 2, image 2 of 2
      • Open the battery cover and remove the batteries from the CD player.
      Ask FixBot
    3. Panasonic SL-MP73J Base Plate Replacement: step 3, image 1 of 1
      • Use your Phillips #00 screwdriver to remove the four 7 mm-long screws from the corners of the bottom interior plate.
      Ask FixBot
    4. Panasonic SL-MP73J Base Plate Replacement: step 4, image 1 of 1
      • Find an opening between the interior bottom plate and the bottom of the player where you can fit your plastic prying tool, and gently lift along the edge using the tool.
      Ask FixBot
    5. Panasonic SL-MP73J Base Plate Replacement: step 5, image 1 of 2 Panasonic SL-MP73J Base Plate Replacement: step 5, image 2 of 2
      • Once you have detached all the connectors with the prying tool, lift the base plate off the interior bottom plate.
      • You may have to turn the base plate slightly to move it past the headphone jack.
      Ask FixBot
Sarah Rukavina
289 Reputation
3 Guides authored
UMass Dartmouth, Team 1-8, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-8, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G8
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 60
All Time: 196
