YLOD repair then relapse
Used YLOD kit and ended up with 4 extra 9mm screws. Worked fine then re-YLODed. Used guide again, replaced thermal paste, put back together, somewhat wonky looking, with 4 9mm screws left. Unit goes to instant YLOD when started. What do I do? Can this be fixed?
1 Comment
I actually used the guide to do this, twice in fact. Will I need to take it apart, remove the thermal paste (which there is a fair amount of), and redo? Also, could I use the heat gun from the kit to heat the board if that would help? The front of the PS3 doesn't look put back together right, and I am still have 4 "extra" 9mm screws, is there a reassemble guide? Thanks for the help.
by theunknown74
