1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Questions View all
Not registering GPU or CPU temperature. How can I repair?
Hi,
I've been running SMC fan control and istat pro to compensate for this problem. I've noticed that the both the CPU and GPU temperature readings do not budget from 32 degrees, therefore, the fan does not seem to adjust on its own for cooling. What inside the computer is measuring these temperatures and can it be isolated and replaced? Thanks.
Score -1
Add a comment
1 Answer
Chosen Solution
You can replace them - the GPU sensor will be a hard one to locate.
If this answer is acceptable please remember to return and mark it.
Score 1
2 Comments:
Should I attempt as a first-timer or not?
by
You coud do that or this.
by
Add a comment
Add your answer
Christopher Collins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 559
