13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Trackpad replacement without keyboard replacement
Can the trackpad be replaced without replacing the keyboard? I have a broken trackpad and can't seem to find a part number for it. My mac is a MacBook Unibody Model A1278.
Thank You
Score 3
Add a comment
Most Helpful Answer
Yes it can! Your part number is 922-9014. You will, however, need a tri-wing screw driver to replace it. Plugging that part number into Google will lead you to the part.
Good luck!
Score 5
Add a comment
Thank You for responding my post. I found the part using the part number you provided.
1 Comment:
Great! I'm glad you found what you needed!
by
Add a comment
I have a late 2008 model Macbook 5,1 aluminum case version. Is this a A-1278? I have a defective trackpad on the unit and need a replacement. Is the part number 922-9014 correct? Thanks, Knut Holzer
Add a comment
Have the same question as above: also have a late 2008 model MacBook 5,1.
Add a comment
Same here. Would love to know.
1 Comment:
These old questions rarely get looked at. Asking a new question brings better results and new things may have been learned in the last year and half.
by
Add a comment
http://www.everymac.com/ultimate-mac-loo...
Yes, they are all the same machine.
Add a comment
Add your answer
avelez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 10,679
