Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
MacBook won't turn on with isight / airport connected to logic board
Hello. I've been given a Macbook Pro where, it seems, the Airport cable was connected backwards. It was turned on, smelled funny, and was turned off. Now, when the cable for the isight / airport is attached to the logic board the system won't start at all. Remove the cable, it runs fine, but without isight or airport.
Any ideas? Is it the logic board, isight, airport, the cable? Thanks!
Score 1
Add a comment
1 Answer
Chosen Solution
Since it starts without the iSight, Airport cables you can rule out the logic board. The camera cable AFAIK is not near the bluetooth/airport connector. Try one connector - to the correct spot - insulate the other connector. I think you may have blown the bluetooth/airport card. When booted what does System Profiler:Bluetooth, then Network lastly Wi-Fi reveal about the state of your cards.
If this answer was helpful please remember to return an mark it Accepted.
Add a comment
Add your answer
RN74 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 660
