iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
How to erase the internal Macintosh HD
My iMac 27 is taking a long time to start and it takes a long time to operate after I push a key on the keyboard so I went to Disk Utility and Repaired Disk. It showed a bunch of errors and said I need to erase the HD, reinstall Lion OS, and restore backup in Time Machine.
I am unable to erase the Macintosh HD and need instructions on doing this.
Thanks
Score -1
Add a comment
Chosen Solution
You'll need to create a bootable Lion CD/DVD or USB thumb drive. Once you have made one you should be able to boot under it to then run disk repair again. If disk repair fails try reformatting your disk.
WARNING! Before you do anything make sure you've made a complete backup of your files onto an external HD.
Often when your disk is having problems you'll loose access to some of if not all of your files after fixing it. These bad blocks will be no longer accessible. If you find the drive is breaking down (Vs corruptions caused by loss of power) you should consider replacing it. If the cause of the problems is loss of power, you should think about getting a good UPS.
Score 1
Add a comment
This answer was originally to another question.
You have to boot from your install disk, use disk tools you can't errase a disk you are running your OS from (like fixing a car engine while it's running).
If this answer is acceptable please remember to return and mark it.
Add a comment
Add your answer
Andy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 803
