Shop the Holiday Gift Guide
Repair, disassembly, and troubleshooting information for the iPhone 15, released September 22nd, 2023. It features a 6.1" OLED display, a 48 MP dual-camera system, and USB-C.
Snapped back flex cable
While removing the back glass of the iphone 15, I forgot about the flex cable, moved the back glass up, and snapped the flex cable connecting the back glass and the phone.
Is my only option here to purchase a wireless charging assembly? Or can I get the flex cable alone?
Replace a damaged or malfunctioning internal inductive charging coil in an iPhone 15. Image
Product
iPhone 15 Wireless Charging Antenna Assembly
$20.99
Add a comment
1 Answer
Chosen Solution
Actually, yes, you can get just the flex cable if you're confident in your soldering skills to make four small solder joints. I'd describe myself as slightly better than average electronics soldering skills, and this is something I would attempt; in fact, I've done a similar repair on an iPhone 11 Pro.
Here's one flex cable I located; there may be more if you continue to search on a phrase like "iphone 15 flex cable for wireless charging replacement".
1Pcs Wireless Charging NFC Coil Flash Flex Cable For iPhone 15 16 Plus 16 15 Pro Max Charger Panel Sticker WPC Pad Tape Parts - AliExpress 509
However, if cost is a factor, the full coil plus cable is only about $1 USD more than the cable alone. If it was me, the main consideration would be whether I wanted to go to the work of removing and replacing the charging coil; it looks like the new coil I linked to does contain the magnets.
Score 1
Add a comment
Add your answer
Tamaam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 56
All Time: 85
