Repair and disassembly information for Sony WH-1000XM4 wireless noise-cancelling over-ear headphones.
No light when charging
Unit sat for along time and now it won't charge
Add a comment
1 Answer
Most Helpful Answer
@alantordoff possibly an issue with the battery having discharged below it's charging threshold. That basically means that the battery has discharged to a point where it no longer accepts a charge. I would start of with a new battery. Use this guide Sony WH-1000XM4 Battery Replacement for that.
A new battery will also give you a known well starting point should it become necessary to troubleshoot further. If the new battery doesn't fix this, you will need to check the charging port and charging circuit.
Score 1
Add a comment
Add your answer
Alan Tordoff (Schnarf) will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 44
