Repairs for most tablet computers. Because of their small size and frequent use of adhesive, tablet repair is often more involved than laptop repair.
18908 Questions View all
How can I fix the charging port on my Android tablet?
I put the charger in my tablet. I have to hold it down or pull it back to charge it but when I tried charging it today, I think I pulled it back little too far, and now it won't charge. I tried adjusting the charging port but it seems to be loose and refuses to charge. I used a USB connection to the laptop but the tablet turns on and says "force to shut down." So, I know it still works but I just can't charge it. I know it's not the charger. Does anyone have any suggestions to charge my tablet without the charger? Please, I really need help. Thank you.
Score 279
22 Comments
If its under a year old don't wait there is a free warranty If its broke u don't need a warranty in the store Just call the manufacturer And tell them its broke and they will replace it hopefully
by
Thank you Ashley for posting this question because i am actually having the same problem to. :D Please help
by
Thank you so much it worked well not really but thanks fro the advice the person that wrote this::
Uhh..get a safety pin or any type of sharp pin. The charger port that's broken, stick the pin in and slide around the outsides, and see if any dirt comes out. If any does, then thats the problem, and if any doesn't, then YA CAN'T FIX IT. If you wanted to fix it, you would have to pay alot, so its no point if with that money you can just buy A NEW ONE! Hope I helped, good luck.
Because it did work and dient wat i did is i got a sowing pin and fixed the socket things and walla it worked thatnks So much
Your sincerly x Amelia winifred
by
take case of strip small bit wire from black and red wire on battery. get old usb lead remove outer wire to revael 4 wire strip black and red conect to wires on bterry and plug usb into pc/laptop it will charge do this myself (last resort but it works)
by
«Its an phisical damage we can't fix devices like that»
It's what the warranty said to me
by
Show 17 more comments
Add a comment
Chosen Solution
asheley, since I do not know what make/model your tablet is, it will be difficult to be specific. Most of the charging ports are micro USB and soldered unto the logic board. A repair of the port would require you to disassemble your tablet, and to (most likely) de-solder the old port and replace it with a new one. Sometimes, it is just the solder that has come loose and might be fixable by just re-soldering. Replacement ports, if it is a standard connector, are usually available at places like Mouser.com or Digikey.com. Hope this helps, good luck.
Score 76
38 Comments:
what in the world that does not help
by
Thank you oldturkey03 that's exactly what I need to do and I've been looking all over to find the part so I can solder a new one in. Know one seems to know what I'm talking about, but you hit the nail on the head. My son while trying to charge his tablet broke the little pins on the port that connect to the logic board because the connection was never tight and he had to wiggle it constantly to get it to charge. I wish these connections would have to click into place they're just to flimzy
by
I have the very same problem and dont know what to do. As I dont want to be without my samsung tab 3 If it has to go back to the shop. But I may not have anyother option.
by
Did you get it fixed ? If so where did you go to fix it and how much did it cost ?
by
What if you lost the receit and can't get the serial number
by
Show 33 more comments
Add a comment
Push try charger down
Score 12
Add a comment
I hope this helps. This link will show you how to repair the charger port !!
http://m.youtube.com/watch?v=YxxpLYf16fc
Score 11
Add a comment
Take the tablet apart and strip the board down to the Motherboard if you have solder experience take the soldering iron , and go on-line a buy a "flux Soldering pen" they are 3.99 on ebay and also get some desoldering braid replace the dc jack you might have a weak joint or a bent pin
Score 8
5 Comments:
This to me seems logical. This kind of soldering is actually not too difficult with a couple practice runs on some other junk devices and a steady hand.
by
This is really only helpful to people that know what you are speaking about. Looking at most of these posts they are by very young people......and a few of us that understand but don't have luck opening things up and having them work after I close them. LOL.
by
I don't know how many comments I have seen saying "Get a Wireless Charger!" but too many when you consider A the models discussed are older or cheaper without Qi charging capability or B the model is just not mentioned. You can't just set any device on a charging pad and expect it to work
by
How about a Samsung 10.1 tablet ?
by
I dont want to take the %#*@ thing apart n fn solder but thank you
by
Add a comment
Score 3
5 Comments:
I was told that its not covered by the warranty.
by
That is BS! Acer has repaired (cough- cough) mine twice under warranty. The second repair is staring to fail. With all the electronics I have with charging ports, my Acer tab 10 is the only one that has been a pita.
by
I called a local computer sales/repair shop and he quoted me $90-$160 depending on the Acer 10 model, Since my gf bought me this 13 mths ago I asked if she had gotten an extended warranty and she did. It goes to Assurion on Monday.
by
I got my tablet back from Assuring and it's charging but the charger port was a bit loose when I got it back so it's only a matter of time before it fails again. The problem is poor design/engineering.
by
I just had to clean up the connections and will see ,it comes on so far ! thanks
by
Add a comment
I can't even with this thread..
I'm gonna keep this in simple English, avoid tech lingo (cause we're here to learn - not make a point), and I realize a lot of you had good/correct ideas but I feel like I didn't get an answer to OPs question because there were so many.
Please open your tablet first (please disconnect the battery before disconnected anything and try not to use metal tools on the contacts!)
Look at everything and if you notice anything that looks weird you should post back here so we can get the right help for you and anyone else having issues.
You might notice the port is connected to a smaller logic board
- if it is it'd be easy to just buy ~that~ part and replace it (yes I realize it doesn't sound cool and there are so many theoretical complications but I trust your judgement and think you'll do fine as long as you try your best!) but seriously don't get the wrong part and break it - please. If you need to see an example what I mean you can Google search a Galaxy S5 Charge Port with flex ("ible cable"), or look at how the Nexus 7 (2013) looks. Yes most of those types have other parts on them so you'll probably want to have a warranty of some sort. Also I have to say this - make sure you're not just buying the whole board (unless you want to) and match everything you can. Size, shape, color, carrier, model number, etc)
If not, please just be careful and if you haven't soldered anything before it might be best to not attempt it and visit someone who will repair it and warranty their work.
^^^And that's the answer - below is irrelevant unless you want to.
I'm not going into how to solder because I'm sure the information is out there, however if that's what someone wants I suppose I can. But make sure you have flux, a soldering iron, people have their own preferences on what solder to use (but there are a couple forums on iFixit about that exact question), low melt solder, a magnifying lens, and a steady grip. (it'd be nice to have an ESD mat too, just avoid building up static, you can touch a metal surface before touching the tablet, and if you can avoid working while standing on carpet.
Yes, this should sound like you gotta go through ~some~ trouble and if you don't work or live somewhere with these things available, it'll probably cost some money to get those things, and although anyone can learn to do this, I wouldn't recommend trying it on something you want to keep the first time you do, if you've soldered bigger things before, its a little different and each contact needs to not have solder touch the other ones. There are tricks to do it quickly and efficiently (ish). Also I have customers always ask me this and I understand but not every port is the same, I wish I could carry hundreds of a single port and it'd be the right one for every device but again check the model.
I'm assuming you want to fix the port and not jerry-rig it - a model number/name would help OP. Please comment if you have any concerns with this comment since I don't want to give anyone any bad info.
Thanks!
Score 3
1 Comment:
Sorry this is a very delayed response but if you still need help you can comment back and I'll be keeping an eye out. If you can post the model # that'd help a lot. Thank you
by
Add a comment
I get this problem quite often. I have a SMD/soldering station, but you can use a hair drier.
You need:
1. hot air source
2. new charger port
3. tweezers
Use tweezers to hold old port while you heat the solder points. Gently lift the old port until it lifts off the PBC board. Discard old port and pick up the new one with the tweezers the whole time keeping the area hot with the air. Set the new port on the board where the old one, was keeping the hot air on it. When it's ready to turn soft and pliable, anchor the port in the space. This process is known as "reflowing". It takes a few times to get better.
note: always have hot air moving, never still.
Score 1
Add a comment
from what I have gathered there are two ways in which this will have been caused. The first is some dirt or muck has got in to the charging. To fix this get a small needle or hair pin and try to clean it out. If this doesn't work it means it was caused by pushing in the charging cable too hard or the wrong way up, making the port it's self break. You will NOT be able to fix this. The best solution is to search into google "your tablet/phone name + charging port" for example: hudl 2 charging port. Now you can either go to a phone shop and ask them to put it in the tablet/phone or to sac money YouTube how to fit the port in your phone/tablet and go from there All the best of luck
Score 1
Add a comment
How to stop split pages
Add a comment
1. You can use the magnetic fixed charging port and cable to charge the iPad. This can reduce wear on the charging port. 2. Unless the device itself supports wireless charging, you cannot charge the device without going through the port. Maybe there are other ways I don't know.
Add a comment
I just wanna say if you can't get it fixed buy a new charger and I know that may cost a lot of money but that's the least we can do!
Add a comment
I have DUODUOGO 10.1 tablet that is 12-14 months old and I ‘ve never had a thing wrong with it. Last night I plugged it i to charge it like I've done dozens of times. This morning I went to use it and the plug of charging cord wouldn't come out. It was stick. I was forced to pull it out with pliers and I'm pretty sure it broke the tablet's socket. I’m pretty heartbroken and depressed because it's not like I have $200 to spend on a tablet every year. (I'm on limited income) The odd thing is that I didn't force it to fit last night. Went on as easy as it usually does. Usually if the plug is upside down it just won't fit and after a couple tries I turn it over. Don't understand why it ‘fit' so easily last night? They should be made shaped so you cant connect wrong. I'm 99% sure a plug won't fit now. (Wasn't standard USB socket) but can't try because cord was end was wrecked when I tried to unplug it.
Why don't they make the tablet sockets easily replaceable? (Socket bases held in with screws / sockets that are unpluggable would be good) I' beginning to hate the unrepsirable aspect of technology. Instead of paying $25 to have a new socket soldered in I will have to pay $150 more to get new tablet. They need to put in easily replaceable socket. This must happen a lot. Very profitable I guess.
Add a comment
Add your answer
asheley will be eternally grateful.
Past 24 Hours: 17
Past 7 Days: 115
Past 30 Days: 466
All Time: 441,990
