13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Question Closed
Grey screen after apple chime.
Hi, my Macbook get a grey screen after chim .
Its happens after i did a upper case swap ( my case was bent). Macbook has no spills or any problems before.
I dont have a mini DP cable to test a video output.
I did memory swap with another Mac- but no luck.
Any suggestions?
Thank you!
I tried to reset SMC and PRAM- no luck
Also tried to boor in safe mode- same grey screen.
I did a upper case with keyboard because my case was bent.
Macbook boots up and i can adjust brightness of the screen and sound volume
but its only no image on the screen.
Thanks
mayer, sorry about that my bad
ordered a mini display port cable to check on the external monitor.
No image on external moniror as well :(
I decide to sell it for parts , but nobody want it
Next step is reballing a gpu Nvidia on logic board
2 Comments
When you just change the question without addressing or acknowledging my answer, it makes my answer look pretty stupid.
by
Let's wait till your part comes in to check the LCD further.
by
Add a comment
1 Answer
Chosen Solution
First I'd like to see if we're both on the same page. Is this what you replaced: MacBook Unibody (A1278) Lower Case
Reset the System Management Control and PRAM:
The link to reset SMC is
http://support.apple.com/kb/HT3964
The link to reset PRAM is
http://support.apple.com/kb/HT1379
Next try starting in Safe Mode by holding down the Shift key on start up.
MacBook Unibody (A1278) Lower Case Image
Product
$79.99
Score 3
1 Comment:
my bad
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,376
