A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
Error code su-42118-6 PS4
My PS4 Slim has random clicking noises at random intervals. My PS4 also cannot update at all and shows the error code "su-42118-6" whenever my PS4 is done updating. It might be a loose blu-ray cable/ribbon. This started after my PS4 refused to read disks.
Add a comment
1 Answer
Most Helpful Answer
Hi!
That error code is pointing towards the Playstation it’s blu-ray drive.
Could be the ribbon cable, power cable or the PCB.
First I would replace the ribbon cable and see what happens. This is most likely the issue here.
Still failing? Try to replace the power cable as well.
Clicking noise is usually the HDD. You can try a known working one as well and see what happens..
Score 1
2 Comments:
i have the same problem, i hear that the drive turning on and everything but still the error when i want to update my ps4. i just bought a ribbon cabel... if its not better than pcb. how can i know if its good or not?
by
Yes, probably for the best to test with a new ribbon cable. Sometimes they do fail. If the error is still there, you might need to check the PCB. Do you also have ticking noises?
by
Add a comment
Add your answer
209 guy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 147
