The larger version of Samsung's flagship phone. Released March 2018.
Galaxy S9+ won't power on after motherboard replacement
Hello.
I replaced the motherboard on my Samsung Galaxy S9+.
Current symptoms:
• The phone charges normally and shows the battery percentage.
• The backlight turns on when I press the volume button while charging.
• However, the phone will not power on.
• The power button does not seem to respond.
I tried:
• Holding Power + Volume Down for 10 seconds
• Holding Power + Bixby + Volume Down
• Reseating the motherboard
• Tightening all screws
The phone clearly has power (charging works and backlight responds), but it will not boot.
Could this be a power button contact issue or something related to the frame contacts?
Any advice would be appreciated.
Add a comment
1 Answer
Have you tried replacing the power button?I had a similar issue in the past & that solved the problem
Add a comment
Add your answer
wani wawa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 48
