Fix error-29 on 3UTools @50% of flashing
Recently I changed the battery of my iPhone 4S and itunes can't sign in then I need to sign in so I decided to restore it with iTunes but it gets error then I tried with 3UTools even switched and tried everything flashing options available for the device on the 3UTools dashboard including flashing from DFU mode but still those tools can't restore my iPhone 4S properly. iTunes just got blind fail and 3UTools gave me error-29.
Is there a way to solve this without using original battery bms tweak by changing the bms from the original battery to the new battery or installing original battery then restore and replace new battery afyer successful flashing and activating the iPhone 4S because I don't have access for the original battery(including the last usedRuggas™ battery too) thrown it unfortunately:/*, it was changed around 2018 and after that I am using another 3rd battery battery from "Ruggas™" and got same issue and bypassed using host file replacement but now I can't if I put the block on my windows host file and try to flash the phone iTunes can't connect to the Apple servers to do pthe proper flashing gave me connection error code for iTunes.
My newer battery brand is called "Moon™" another Chinese brand, same as "Ruggas™"
I don't know why it blocks update and why I can't bypass the issue wirh the host file method on this battery like what I do for Ruggas™ a long ago.
