Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
Failed repair, screen goes white.
I followed the iPhone 3gs front display repair guide. It went well right up until step 10 when I'm removing the Phillips#00 screws. Since the screw itself could not come off, and was worn down from failed attempts at the screwdriver, the screw became too rounded to screw out. So As I removed all the screws except for one, I dislodged it from the side part. The LCD itself and everything around is still intact, as far as I can see all I did was damage the screw to hold it in place.
So I proceed to install this onto the new display and mount it onto the phone. I manage to put the cables 1,2, and 3 back in but I'm not sure if they are damaged. After mounting and pressing the lock button, the white screen of death appears.
I suspect the damage is either from the LCD, the cables, or worse the motherboard. Please help
Add a comment
Chosen Solution
First step with White Screen is Reset, hold both home and power buttons until the iPhone begins to start. Like Hector recommends before opening and during repair of iPhone 3GS make sure iPhone is OFF.
Score 1
Add a comment
Most Helpful Answer
Sounds like the LCD is damaged. Try a different LCD and install with the phone OFF.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 8
All Time: 917
