Water Pump Constantly running
I have a problem with my delonghi coffee machine. the water pump is constantly running with the water going to overflow tray. As soon as I plug the machine to power socket the water pump starts running (even if machine is turned off). What can be the solution please?
Add a comment
1 Answer
Most Helpful Answer
@victor17222 Which model ist it? ETAM ???? I think its an issue with the motherboard, perhaps it must be replaced.
Score 1
2 Comments:
It is Etam cappuccino Eletta, so pcb board then?
by
@victor17222 Look at the type plate: it should look something like this ETAM 29.666 or ETAM 36.366. There are essentially two different circuit boards, but you need to know the exact part number, printed on a sticker. Both cost around €65. Or try to have it repaired; there is a special workshop.
by
Add a comment
Add your answer
victor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 155
