How to change SSD
Hello. Does anyone here know whether it's possible to change the SSD in a Lenovo ThinkPad T470p (upgrade from 256 GB to 1 TB)? I only saw guides for the T470 and T470s.
Hi @anneschu
Here's the hardware maintenance manual for the laptop.
Go to the bottom of p.66 (72 of 106 pdf) in the manual, to view the procedure to replace the SATA storage drive.
The M.2 SSD removal procedure follows on p.68 (74 of 106 pdf)
Thank you! Will try and follow this.
Yes, you can upgrade the SSD in a Lenovo ThinkPad T470p from 256 GB to 1 TB. The T470p supports an M.2 NVMe PCIe SSD and a 2.5-inch SATA drive, so you can replace the existing SSD or add a second one, depending on your current configuration. To upgrade, power off the laptop, remove the bottom cover, disconnect the battery, and replace the existing SSD with your new one. After installation, reassemble the laptop and reinstall Windows or clone your old drive. Always back up your data before upgrading and check the BIOS for proper SSD detection afterward.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 37
All Time: 579
