Repair guides for smartphones manufactured by LG that use the Android operating system (OS).
2555 Questions View all
Looking for a digitizer...can't find one
Lg mytouch LGE739
Yes I have a potential customer with a lg mytouch LGE739 from tmobile...broken digitizer...I can't find the digitizer anywhere...looking to see if anyone else has found one...thanks
Score -1
2 Comments
I've been searching for the exact same thing for the past 2 days. If you find a source, please let me know as well! If I find one, I'll let you know.
by
I found two on eBay yesterday...little bit expensive... http://www.ebay.com/itm/Tmobile-LG-Mytou...
by
Add a comment
Chosen Solution
I'd go straight to the horse and ask, here's where: http://www.partselect.com/Entry.aspx?Bra...
Score 2
Add a comment
I have two of the same model and bought screens form repairsunivers but they sent two different parts and shortly after I raised an issue removed the phone part form there site.
Here is the right part. Hope it helps you guys.
http://www.alibaba.com/product-gs/602868...
embly.html
To remove the old screen if you havent allready remove the back the screws the battery and then the back cover.
undo the pop connectors and remove the motherboard.
then use a blow dryer and a 2in flat flexable metal putty knife it will break the glass and lcd but you can not help this as they are glued in. Clean all the junk of the plastic and use 3m double side phone screen tape. around the screen edges.
Score 1
Add a comment
Add your answer
rudpriss will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,108
