Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
New 3ds lcd issue
Good day ladies and gents
I have a new 3ds of which I have an issue with the lower screen. The device powers on , but only the top screen shows up. The bottom screen is black but the touchscreen works. I have replaced the lcd bottom screen twice but to no avail. The ribbons are secured, the ribbon clip is fine and clean. This applies to the lcd and light connectors. Could I ask if there is anyone that has a solution please
Many thanks
Tobi
1 Comment
This question was migrated from https://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Chosen Solution
Hi Tobi!
Well, then it’s most likely motherboard related. Does the screen shows anything? Maybe the blacklight is just dead. You can check with a flashlight on the screen.
In the worst case, a motherboard replacement is required.
If you can sent any photo, that would help, thanks!
Please let us know how it goes!
Score 1
2 Comments:
Hi there. I did think it would end up being the lighting issue. I will try and get some photos accoss on here. And thank you for your response 🙂
by
My pleasure! That would help, thank you :)! Then it's most likely something on the motherboard causing this issue. Can be a lot of components. Running tests is required to check for the backlight!
by
Add a comment
Add your answer
SplitPancreas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 213
