Why is my wifi adapter not working?
In device manager the wifi adapter is showing (code 10) error.
Is the latest Realtek Wireless LAN Driver Version 2024.0.8.107 2019/05/28 installed?
Also check in BIOS - Security (or Advanced) for any settings relating to WiFi e.g. I/O interface or Onboard Configuration to check if the WiFi has been disabled.
I have been worked with this issue. The simplest and easiest solution is if there are no software issue or driver issue.
If you go to service centre they will change entire wifi bluetooth module and they will cost you decent amount of money without any reason.
# plug it out clean the yellow part with eraser or recommended cleaning solution. (I have done it with eraser)
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 196
