Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
What kind of glue Apple uses on iPhone 3G* digitizer
i would like to know what kind of glue apple uses to keep the digitizer screen to the frame, i know uses 3M adhesive strips, but theres a thin line of blue/clear glue like silicon or epoxy that strength the digitizer.
so far, i been using:
3M adhesive strips= hold ok for a couple of days, but always get loose on the top right corner.
3M adhesive + super glue=BAD alot of mess
3M adhesive +Loctite GEL Control = OK, but not so much.
Do somebody know which glue Apple uses? it should be the same on the screen and chrome bezel to back housing.
i been searching alot on the forums and google, but could not find an answer.
Score -1
Add a comment
1 Answer
Chosen Solution
I like this stuff but use it sparingly as it expands: http://www.gorillatough.com/index.php?pa...
Score 2
1 Comment:
Do not push the screen away from the frame or gasket when expand/dries? I will try.
by
Add a comment
Add your answer
Luis Zarate will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 1,200
