Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
iPhone 5 LCD separating from frame.
I tried to replace the battery on an old iPhone 5 that i have but the LCD separated from the frame, despite removing the two pentalobe screws. Anyone know how to prevent this from happening again and how to pry off the remaining part.
Add a comment
1 Answer
Most Helpful Answer
You haven’t put your opening tool into the screen incorrectly. Put it between the plastic frame and the metal body then pry it up gently. Do the same around the frame except the top which is located by tabs. If the screen still works after you get it out buy some B7000 adhesive to fix the screen back together.
Score 1
Add a comment
Add your answer
Henry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 138
