After glass/screen replacement - NO SOUND
I have no sound after I replaced the screen and glass in an Ipod touch 4th gen. Any ideas?
When taking the mid steel frame away from the logic board did you start prying from the bottom left ? If not, you may have lifted the speaker(which would have been still stuck to the midframe, down to adhesive) and broke the red/blue cable.
A quick thanks for your answer here, have been searching for the same fault, and a quick check after reading this revealed I had broken the blue cable! After a short soldering job, the device is back up and running 100%. Thanks again for the help.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,501
