Model No. A1367 / 8, 16, 32, or 64 GB capacity
913 Questions View all
After glass/screen replacement - NO SOUND
I have no sound after I replaced the screen and glass in an Ipod touch 4th gen. Any ideas?
Score -1
Add a comment
Most Helpful Answer
When taking the mid steel frame away from the logic board did you start prying from the bottom left ? If not, you may have lifted the speaker(which would have been still stuck to the midframe, down to adhesive) and broke the red/blue cable.
Score 1
Add a comment
Did you check all the connections?
Add a comment
A quick thanks for your answer here, have been searching for the same fault, and a quick check after reading this revealed I had broken the blue cable! After a short soldering job, the device is back up and running 100%. Thanks again for the help.
Add a comment
Add your answer
Matthew McCracken will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,500
