The Craftsman Walk Behind Mower 900.370510 is a 52 lbs electric lawn mower that requires 120 volts and 12 amps to operate, featuring a cutting width of 19 inches, adjustable height positions, and a folding handle for compact storage. This page contains repair and detailed information about the product.
How to clean the mower deck
My mower won't start, how do I clean the mower deck
Add a comment
1 Answer
Personally, I use a pressure washer to clean the underside of the deck. You can turn the mower on its side and either use a pressure washer, or (as I did in pre-pressure washer days) use a gasket scraper or putty knife to scrape the underside of the deck. If you'd rather not turn the mower on its side, placing it up on two inverted 5 gallon pails should give you the clearance to get under there with your putty knife.
As for the starting problem, presuming this is a 120 volt plug in mower, a clogged deck could prevent starting. Short of that, be sure the plug is tight in the outlet and that there is power to the outlet.
Add a comment
Add your answer
cookiechu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 130
