Repair and disassembly information for the Pixel Watch, Google's first entry in the smartwatch device category. Released October 13, 2022, and identified by model numbers GQF4C, GBZ4S, and GWT9R.
Google watch submerged in the water
google watch submerged in water
The power doesn’t turn on
Could you please tell me the cause and how to fix this?
Add a comment
1 Answer
Most Helpful Answer
Hi @ryoumaruumaruu
The watch is classed as water resistant, not waterproof but this is when it left the factory. However over time, water resistance can decrease due to wear and tear, or damage.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the watch's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your watch and then remove the battery as soon as possible from the watch to minimize any further damage.
Then you need to dis-assemble the rest of the watch and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the watch might possibly work correctly again.
Here is the ifixit Google Pixel Watch repair guide that may help.
If this process seems too daunting, take your watch to a reputable, professional electronics or mobile phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 1
Add a comment
Add your answer
Ryo Umaru (Umaruu) will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 29
All Time: 326
