Shop the Holiday Gift Guide
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Touchpad not found after replacement
Hi all -
Original symptoms were short battery life and touchpad physical clicking not working. I bought a replacement battery and touchpad.
Battery was definitely bulging and putting pressure on the touchpad. I swapped out both and when booted back up - no mouse movement or clicking at all from the touchpad. External mouse works fine, so I went into system preferences and then Touchpad. It said "Touchpad not detected" or something along those lines and had a spinning circle indicating that it was searching for bluetooth touchpads.
So I opened it back up and swapped in the original touchpad - mouse movement but no clicking. But still, system preferences says it doesn't detect a touchpad (I was hoping to at least turn on tap to click.)
So, what am I missing? Is there some extra step to set up the touchpad with the OS? Does the lack of movement on the replacement pad mean that it's DOA?
Thanks for any help!
Score 1
Add a comment
Chosen Solution
Did you also replace the trackpad cable with the trackpad MacBook Pro 15" Trackpad Cable (13/14) the cable holds the interface chip which can get damaged.
Score 1
4 Comments:
Yes, the new trackpad came with a new cable. I haven't removed the cable from either pad, just disconnected from the logic board
by Share
@agitatedgopher - Try replacing the cable with a fresh one. I’ve hit a few bad ones as I suspect the chip is a bit static sensitive (ESD).
by Share
Oh, I forgot to come back here, but yes, that fixed it! Went to a mac repair shop, showed them what I needed, the guy in the back who knew everything got me a cable, and I forgot what they charged me for it, but it's working happily now.
by Share
@agitatedgopher - That's Great! Don't forget to score and accept the answer so others find the solution. Thanks!
by Share
Add a comment
Most Helpful Answer
Have a look at the MacBook Pro 15" Retina Display Mid 2014 Logic Board Replacement & check step 25 for the touchpad connection to see if it is correctly seated. This maybe your issue.
Score 1
2 Comments:
Well, that was the first thing I tried, reseating the connector. Still no change. Then I reinstalled the original pad and got mouse movement, but it still doesn't show up in preferences. Then I switched back to the new pad and it's still no movement and not showing up in preferences
by Share
@agitatedgopher Hmmmm.... Maybe @danj can give some thoughts....
by Share
Add a comment
Add your answer
AgitatedGopher will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 287
