Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
799 Questions View all
Question Closed
No hard drive spin?
Hi,
So I recently purchased an iPod video 5th gen, had a smashed screen. I took it apart fitted the screen, looking forward to see it working... Oh no! I get the 'sad face error'.
Can somebody tell me whether it could be the ribbon or the hard drive? I thought to myself, how can it be a hard drive fault, it was working the night before, and I never knock it hard etc.. So it must be the ribbon right? The hard drive doesn't spin, but it was working last night, playing music and that!
Many thanks, please help!
P.s on the hard drive ribbon they is two lines. I can see one of the lines, does it have to be so you cannot see any?
Add a comment
Chosen Solution
Solewolf67, double check your work and make sure that the cable is inserted straight, and that you have it properly connected, on both ends. Yes, you will see one line. It is possible that it is your cable, and it is also possible that it is your HDD. After all, you are dealing with a used iPod, and you are dealing with someone elses problems. I would invest in a USB-to-Zif adapter and use it to check the HDD. The adapter runs about $5. Of course, you also want to change the cable, just to make sure it did not break internally when the screen got change. Hope this helps, good luck.
Score 1
Add a comment
replace the ipod
3 Comments:
Why should Solewolf67 do that?
by
Why not just close this site down?
by
and then what are we going to do with our spare time? I would probably have to get another real job.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 308
