Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Stuck on headphones mode
My iPhone stuck on headphones mode tried to change a charging p still not working
Add a comment
Most Helpful Answer
Just to verify, you tried changing the charging port, right? That's the lightning connector assembly that comes with a new headphone jack; that's what you replaced, is that correct?
There is a contact inside the headphone jack that switches between headphones and the speaker and if that is damaged or jammed, that would be my first guess as to the cause, but if you've already replaced it with no change then you're looking at either a connector issue on the motherboard or other kinds of problems as described by @tzfadly.
Score 1
Add a comment
Check the HPHONE_TO_CODEC_DET_CON line. The expected value should be 0L.
If the reading shows 0.000, it indicates a short circuit in that line, which triggers headset mode.
Inspect capacitor C1816 for any signs of corrosion. If it’s clean, try removing resistor R1801 as a test. However, note that removing R1801 will disable the headset function.
If the issue persists even after checking these components, the problem likely lies in the audio IC U0900 (IC 338S1201).
Add a comment
Add a comment
Add your answer
Dex Walker will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 14
All Time: 88
