dropped it in my pool
dropped it in my pool went under for about 20 sec fully submerged and it doesnt want to turn on what has happened.has power when charging but no power when off charge.i havent taken it aprt but let it sit for more then a month now and is completly dry.???
Add a comment
1 Answer
Hi @marcuscourtenay
The speaker has an IPX7¹ water rating, but this was when it left the factory. It might depend on how it has been handled since then whether it is still fully waterproof or not
It seems too much of a coincidence that the speaker has failed after being submerged, even for a short period of time.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the speaker's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your speaker and then remove the battery as soon as possible to minimize any further damage. Although after a month it may be too late anyway. You can only try.
Then you need to dis-assemble the rest of the speaker and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a links that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this, it might possibly work correctly again.
Here is a teardown video that may help
If this process seems too daunting, take your speaker to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later
¹IPX7 = protection against immersion in water up to 1 meter for 30 minutes,
Add a comment
Add your answer
marcus courtenay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 89
