My DJI mini 2 controller won't charge
My DJI mini 2 controller will not charge
If your DJI Mini 2 controller isn't charging, first check that you're using the correct charging cable and power source, then try using a different cable and charger to see if the issue persists; if it does, the problem might be with the controller itself and you should contact DJI support to potentially send it in for repair.
this forum is called " I fix it" not "DJI repair shop fixed it" :-)
This is somewhat outdated now I guess, but did you fix it in the end? If you're a technician you've probably taken it apart?
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 321
