CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
418 Questions View all
How to remove the back glass on iPhone 4 Verizon?
I have a replacement back glass panel for my phone and was expecting to remove the old one easily. All of the instructions I read say that I should remove the screws, which I have done, and then I should be able to push the back panel out easily. My phone's back panel refuses to budge. How can I remove it?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Remove the two Pentalobe screws and then slide/push the Back Cover up towards the top of the iPhone about 2-3mm. Then just lift the Back Cover off. If it is on very stiff, push down on the back as you firmly slide it up the 2-3mm.
Score 1
Add a comment
Add your answer
Sarai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 6,870
