Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
554 Questions View all
Is the drive belt bad or is it the transaxle
The mower is an automatic 18.5hp 46" cut, model 917.272040. I put the mower into drive or reverse and it whines. When I put it into neutral it stops. I tried purging the transmission but that did not work. I dropped the mower deck and the drive belt is loose. I also noticed oil on the bottom of the transaxle. What should I do next, replace the drive belt or the transaxle.
Score -1
Add a comment
1 Answer
Chosen Solution
Brian, you said the belt is loose, first make sure the drive belt is not slipping. Try adjusting the belt slightly tighter to see if it helps. If it doesn’t help, the transaxle will probably be the problem. Since you have some oil on the transaxle, it may be low on oil or overheating. Hope this helps, good luck.
Score 2
1 Comment:
Thanks. I will try it.
by
Add a comment
Add your answer
Brian will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,487
