Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
broken plastic tap on cable 3
Hi
while replacing the battery of my iPhone 3gs I accidentally broken the plastic tab holding the ribbon cable number 3 in place...as a result although I have put the ribbon cable in place an the rest of the functions of the phone are ok I have no speaker...
any suggestions please?
Add a comment
1 Answer
Chosen Solution
If you kept the plastic piece you could possibly try repairing it by using a plastic melting iron. Or maybe possibly use tape and see if holding the ribbon in place works, though probably isn't a permanent solution.
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 609
