Repair and disassembly guides and support for dish washing appliances.
dishwasher door will not open
My dish washer door will not open, I think the power went off during cycle and the controls are on the top of door which is locked
Add a comment
1 Answer
If your dishwasher door won't open when you pause the cycle, it's likely due to a faulty door latch mechanism, where the lock remains engaged even after the cycle is paused, preventing the door from opening; this could be caused by a build-up of debris, a worn-out latch, or a misaligned strike plate.
Some things to check:
  • Clean the latch
  • Check the strike plate
  • Inspect the door seal
  • Check for alignment issues
  • Check for a child lock
What to do if cleaning doesn't help
  • Adjust the latch tension
  • Replace the latch
  • Check for broken components
Important points to remember:
  • Safety first
  • Consult your manual
  • Professional help
Add a comment
Add your answer
WILLIAM MULCAHY will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 336
