Repair guides, support, and troubleshooting information for the 2022 13-inch MacBook Air, featuring Apple's M2 SoC. Released on July 15th, 2022 and identified by model number A2681.
Keyboard and touch id replacement
Hi, I would like to change the top case of the MacBook Air 2022 for some problems on the keyboard and that one has the Touch ID button connected to the T2 chip. But should I do as it was done before with iPhones?
Add a comment
1 Answer
Hello, Yes, the Touch ID is serialized with the Motherboard. Which means that if you are going to replace the keyboard, then you are going to need to keep the Touch ID Sensor.
Best of Luck to you!
12 Comments:
thanks. also i need to migrate the small logic board under the motherboard? what a rage, to fix the small hook of the space bar I have to replace the whole upper case with the keyboard ....
by
@davidemaglio - Check your warranty coverage! some countries offer two years. You might get it covered!
by
@danj Now that you mention it, doesn't apple double their warranty if you buy with a specific credit card? They might get 4 years of coverage depending on how they bought it.
by
@jmehnert and @danj, I know but I'm about to buy a used MacBook Air. the only hope I have is that the warranty on the serial has not expired and try to have it repaired, but I see it difficult to prove that it broke accidentally... (although I would like it so I could put the US or UK International keyboard, I prefer it to the IT one)
by
@jmehnert - The extended card coverage is via the card company, not Apple directly (they handle the repair).
by
Show 7 more comments
Add a comment
Add your answer
Davide Maglio will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 39
All Time: 480
