Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
Can one change out the logic board?
IPhone got wet, dried it, changed battery and charging port but the logic board even after cleaning looks discolored on some contact points. Is it possible to change out the logic board? Or is that going too far?
Add a comment
1 Answer
Chosen Solution
Swapping Logic Boards in iPhones is very easy. However where to get a good Logic Board is a problem. Even if you could find one it would probably cost more than an iPhone to begin with. Also, with water damage, not just the Logic Board suffers. So you still have an iPhone shell with compentents that could have water damage which could fail in the future.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 514
