Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Question Closed
Battery issue help asap
So here is my dilemma, I cannot take out one the screws holding my battery in my iPhone 4s. So my question today is can I perform a swapping of my LCD screen and back cover without taking out the battery??
Add a comment
Most Helpful Answer
No. The back can be replaced but you must remove the battery to get the LCD/digitizer out. What is the issue with the screw? If its stripped the tools you need are offered here on ifixit.
Score 2
1 Comment:
the bottom screw holding the battery connector is stripped, i tried the glue method, and that was a epic fail, I tried taking my mothers tweezers and that was almost as epic as the first failure and even tried a rubber band trick. I really want to get this screw out because if not, buying the LCD/digitizer and back cover would be a waste. . Any suggestions on what I need to get from here to get that sucker out? Your help is very much appreciated
by
Add a comment
OK, maybe not the best idea, but you can try to heat up the screw with a small soldering iron.
Let the tip bear a small ball of solder, tip it onto the screw for best thermal transfer.
If the thread weaks up, unscrew carefully.
ATTENTION:
Three mistakes can be made:
1) If the screw is made from brass, iron or any solderable material, the solder may find a way to bond. That means you need a replacement screw!
2) the solder falls apart the tip and ruins some electronic - if you fear that, don't use a solder ball. Try it with the clean tip instead.
3) when you heat up the screw, you´ll also heat the thread into that the screw is fixed. If this thread is made from plastics it could melt...
This method is recommended ONLY for crafters. I guess you will do fine.
Add a comment
Ifixit offers a precision screw extractor set for 20. It should work for your situation
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 549
