Why can't put the key in the switch to start my car
Small stick stuck in the car switch and can't put the key in to start the car anymore,
If there are still pieces in there and the key is pushing the debris and pin tumblers down the barrel won't turn. The stick may have lost pieces that are still in the ignition, remove them. As I'm sure you removed the stick your helpful tyke placed in there if there are pieces in there you may be able to blow/vacuum them out. Use a duster or something similar.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 67
