Up to 20% off select tools
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Changed pressure switch, keep getting error code
I posted this earlier and didn’t get any responses so I’m trying again. I started getting an error code and was told the pressure switch was probably bad so I just replaced it. Tried doing a cleaning cycle but I keep getting a SUD error. Looking for help so my wife doesn’t just run out and buy a new machine.
2 Comments
Hi @mcap20026
What is the model number of the washer?
by Share
110 47789701
by Share
Add a comment
1 Answer
Chosen Solution
Hi MCap,
Looks like you're not the first person with this issue that's had the same problem, so I'd say the place to start would be with the other guys who went through it.
SOLVED: Why am I getting a SUD error message? - Kenmore Elite HE3 Washing Machine - iFixit
In some cases the pressure switch fixed the problem, but there were several other cures that were found by various methods.
Finally, there's a technician's manual on the device page that has troubleshooting steps you can try.
Duet-Aid_also-Kenmore-HE3.pdf - iFixit
Give that a look and try some of the solutions then come on back and let us know what you found. We find that we can usually learn something from both successes and failures, so be sure to update your question with the results.
Score 1
2 Comments:
Thanks for the input. I can’t seem to find anyone who has had a problem where after a minute of running a SUD code will come up even though there isn’t any soap in it. I’m also still getting the F35 code after replacing the pressure switch. The tech guide looks like it’s for a dryer so I’m not sure if I can use it or not.
by Share
@mcap20026 Ah crap, you are absolutely right; I didn't look past the title since it was on the washing machine device page. I've edited my answer to include the other manual from that page instead, which IS for a washer. Sorry, my bad.
by Share
Add a comment
Add your answer
MCap will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 10
Past 30 Days: 21
All Time: 272
