The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
I can't enter safe mode if pressed
alo semua mau nanyak ps 3 saya tidak bisa masuk ke mode safe kalo ditekan dia akan berwarna merah tanpa ada berbunyi,lampu indikator hdd tidak menyala apa itu terjadi dikerusakan hdd?,layar tv menampilkan tidak ada sinyal
Translation Indonesian - English
Hello everyone, I want to ask my PS 3, I can't enter safe mode. If I press it, it will turn red without making a sound, the HDD indicator light won't turn on. Did this happen when the HDD was damaged?, the TV screen shows no signal.
Add a comment
1 Answer
Most Helpful Answer
Hi!
When you can’t enter safe mode, it’s most of the time caused by the motherboard!
But lets try another known working hard drive first! Be sure it’s formatted on the PC and that there is a partition on it. Then put it in your PS3 and it should give you an error on the TV! Now put a USB drive in with the PS3 software on it and install it.
This should work. If not, it is motherboard related, then you do need to take it out to check.
Please let us know how it goes!
Score 1
Add a comment
Add your answer
Raditya Hanafiah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 96
