Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36501 Questions View all
How to open 1.2mm and 1.6mm philip screws?
I was trying to Open the Screws mentioned in Step 8 in your user guide with Philip #00 screw driver but i was not able to. You have mentioned in guide that its a 1.2mm and 1.6 mm philip screw. what should i use to open it?
Score -1
Add a comment
Chosen Solution
Hi Rajesh,
I suppose you are talking about step 8 of the iPhone 4 repair manual...
If the Phillips #00 screwdriver doesn't work, try to use a different mini slot screwdriver that is small enough to (deeply!) fit into the screw.
As you gently press and hold the screwdriver on the screw, gently and slowly try to turn it. Don't press to strong.
It seems to me that tiny screws are sometimes pretty "sensitive" and like to be treaten "softly". In my experience, sometimes less pressure and force seem to be the key.
I hope this helps.
Steffen
Score 1
1 Comment:
Hi Steffen,
I only have the tool kit which i bought online ( which has one Philips #00 screwdriver and one flat head). Please suggest me the next lower level tool which i should buy. Your help will be appreciated.
by
Add a comment
Hi Rajesh,
I am not familiar with the screwdriver systems here in the States. You might go to a store with your Phillips screwdriver and compare it with a smaller screwdriver that fits better into the screw.
I don't know if you screws or screw driver are already worn/foozled out. In case they are, try to use some aluminum foil and wrap it around the top of the screw driver one or two times. This might give you a renewed tightness between the screwdriver and the screw. Then try to loosen the screws again. Be careful and always be gentle to these mini screws.
Steffen
Add a comment
Add your answer
Rajesh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 5,449
