How Do Open A AirConditioner
My Aircon Is Leaking Inside The House I Want To Open But I Don't Know How Open The Aircon Company Is Energy Star. I Wanna See If It's clogged or frozen inside
Your drain is plugged with crud or mold causing the drip tray to overflow into your house. OR you do not have the unit installed so that it tilts slightly toward the drain. You may be able to ream out the drain clearing the blockage with a small plumbers snake (by hand, not a drill)... if the drain hole is too small some stiff electrical wire should fit to use as a snake. Use the best fit wire gauge in American wire gage every 6 gauge decrease gives a doubling of the wire diameter, and every 3 gauge decrease doubles the wire cross sectional area.
If this Answer is helpful please remember to return and mark it Accepted.
Personally for condensate drains most people blow with co2, I prefer using a shop vac.
Lots of condensate drains are barely glued together (pvc). Running the risk of bursting them behind a wall isn't worth it.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 3,281
1 Comment
Brandon, do you have a model number or any other information on your A/C?
by oldturkey03
