13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Should I replace the LCD or the LCD Cable?
About a year and a half ago, I stepped on my Macbook Unibody and the glass cracked. I sent the laptop off and got the glass fixed, the LCD was working fine at the time. It worked for a while but sometimes the glass would fall out because it was not glued back in too well. About 6 months ago, the LCD started being off color on about a 1.5" vertical strip in the middle of the monitor. Over time it's gotten worse. After taking out the LCD and re-connecting it, it worked for a while and then got to the point where it's always black. Watch this short video to see the exact state that it's in:
http://www.youtube.com/watch?v=IFNYvckFq...
I'm wondering if anyone has a suggestion as to what I should do given that to me it looks like there is an issue with the cable and not the LCD. These are the options I'm currently considering:
1) Just use this as a backup connected to a monitor.
2) Buy a replacement LCD monitor and hope that the monitor is actually the issue.
3) Send it off to get fixed.
Any advise is appreciated.
Chad
Score -1
Add a comment
1 Answer
Chosen Solution
If your going to use the "shade tree mechanic's" DIY process & replace parts until the broken one is found, a cable is much less expensive than the entire LCD. Start there. OR Ask Apple to give you a depot repair for under 300$ that's a good #3.
Good Luck
If this Answer is helpful please remember to return and mark it Accepted.
Add a comment
Add your answer
Chad Skeeters will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 636
