Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Which is the correct replacement battery?
I recently ordered a replacement battery number 616-0435 for my iPhone 3GS. I replaced the battery and checked the number at the time and am 99% certain it was the same, unfortunately I threw the old battery away. I am now having problems, the phone reboots intermittently and does not show battery usage properly - it stays at 90ish% all day then expires completely without warning. I have reset the phone but that has made no difference. The battery may be faulty but I wondered if it is possible to define the correct battery for this phone? It is model no. A1303 8Gb, is there anything which might define the correct battery?
Thanks
Score -1
Add a comment
1 Answer
Chosen Solution
This is the correct battery for iPhone 3gs. 3gs only work properly with 616-0433,434,435. below one work with 3g only. if you are using the original battery then it should be the same. if you are using the after market then 3g also will work becoz you know that are not properly made by original company.
Add a comment
Add your answer
Martin Rookyard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 603
