Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
replaced battery and the battery percentage display is faulty
I've just replaced the battery for my iphone 3gs as my phone just kept turning itself off halfway threw calls and was advised to replace battery which i have but now the battery percentage display doesn't seem to be working properly as it stays the same after its been charging for a good while for example it's showing me that the percentage is at 58% whether i have had it charging for a hour or been using it all day,I have noticed though that if i turn it off then back on it seems to update the percentage to a more true reading as it was 58% then i turned off and back on and its now43%,can anybody help me with this,thanks
1 Comment:
What APN is the new battery you've installed and where did you buy it from?
by
Add a comment
1 Answer
Check correct positioning of the mainboard. Try to allign with "center-holes"...
Battery maybe dedicated to 3G and not for 3GS.
Cheers
Erik
1 Comment:
i brought the battery from this website,to be honest i think it is for the 3g but didn't think it would of made any difference,do you think thats the cause of my problem ?
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 790
